![]() Click here to return to the Prowler Online Board Main Page ![]() |
Author | Topic: Stock thermostat...does anyone know? |
Silver Y2K![]() Prowler Enthusiast From:North Richland Hills, TX |
![]() ![]() ![]() ![]() ![]() ![]() What type of thermostat comes in the stock Kat? 195 degrees? Has anyone tried a 160 degree thermostat to control the heat on the Supercharged Kats? (This is usually suggested even if you just do an EPROM upgrade.) ------------------ |
jd2ksilver![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie Personal ScrapBook From:Mt. View, CA |
![]() ![]() ![]() ![]() ![]() ![]() Bryan I was told by several DC people not to try to change the thermostat to a different degree type. They were very adamant about this as it causes the computer to adjust to the temps in the cars engine. I'm sure there is a more technical explanation but I don't have it now. Dan P and I have been working on a project with a new 4 row radiator. Dan's site has the info so far if interested. Also, the thermostat is already open, or should be when the cars are put to the heat.
This message has been edited by jd2ksilver on 11-08-2000 at 08:29 AM |
![]() ![]() ![]() ![]() ![]() ![]() Thanks, I appreciate the info. ------------------ |
