Author | Topic: Nose-piece Bolts |
Melissa Santory![]() Prowler Enthusiast From:North Grafton, MA |
![]() ![]() ![]() ![]() ![]() ![]() We got quite a surprise this weekend when we went under the car to install our new Wonder Bar, got to the step that tells you to remove the two bolts that attach the nose-piece to the frame - and found none. ![]() ![]() Does anyone have the info/specs for those bolts? Can we get them at a retailer, or do we need to go through the dealer parts department? Thanks! |
MDProwler![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Fallston,MD USA |
![]() ![]() ![]() ![]() ![]() ![]() There are many bolts of that style on the car. The nut is just a speed nut clipped on the bracket it bolts to. It is the same sizeas the bolt that holds the engine bay cross braces down to the radiator support. Nothing really special but a dealer body shop would probably have something. Or just Home Depot. |
392HEMI![]() ![]() ![]() POA Site Supporter Prowler Junkie From:The Villages, Fl. |
![]() ![]() ![]() ![]() ![]() ![]() Side Panel bolts and nut is exactly what you need. Take one off and hit the Home Depot or a hardware store. |
![]() ![]() ![]() ![]() ![]() ![]() they are metric,10mm head dont know thread size,take one from the top of side panel,its the same.ace or true value carries them. ------------------ |
![]() ![]() ![]() ![]() ![]() ![]() I believe the thread size is a 6 or 7 MM. You need two about 3/4" long. |
