This topic has been transferred to: Technical Questions & Answers |
Author | Topic: first oil change |
Danielle![]() ![]() POA Site Supporter Prowler Junkie From:Punta Gorda FL. USA |
![]() ![]() ![]() ![]() ![]() ![]() It's time for my first oil change and I would like to know what everyone is using. Did anyone change to synthetic? I live in Northeast Pa. but don't drive the car Dec.- April. Thanks, Prowlet |
![]() ![]() ![]() ![]() ![]() Get Mobil 1 synthetic 10W30 and a Purolator Pure one oil filter...your Kat will love you for it .... Jim |
pumpkin![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie Visit Waleke's World Personal ScrapBook From:Las Cruces, NM, USA |
![]() ![]() ![]() ![]() ![]() ![]() Same here for Pumpkin, mobil 1. The best gets the best. More 'Pumpkin' photos and Mod Stuff . . . . . . . Our other cars and stuff "I may have to grow older, but I do not have to grow up!" "The Prowler is not a car to go from Point A to Point B. The Prowler is the Point!" This message has been edited by pumpkin on 09-04-2006 at 09:57 AM |
GRROWL![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Herndon, VA |
![]() ![]() ![]() ![]() ![]() ![]() quote:Agree 100-Percent. (NOTE: emphasis on Purolator PURE ONE oil filter) |
quincy![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Fairfield Glade, TN. USA |
![]() ![]() ![]() ![]() ![]() ![]() Halicat is 100% correct! The part number for the Purolator filter is PL14670. It has a built in oil drain back flap that could help prevent cold start valve train 'tick'. Be careful on the oil fill. My 99 calls for 5 qts in the manual. It really only takes 4.5 qts. Play it safe, start with 4.5 and add if necessary! Some Prowlers take 4.5 some 5.0.......don't know why. |
![]() ![]() ![]() ![]() ![]() ![]() mobil 1 and mopar filter.the purolator filter is no different and does not stop the startup rattle.due to its high heat tolerance i will nver use regular oil again. ------------------ |
TooHipCat![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Londonderry,NH |
![]() ![]() ![]() ![]() ![]() ![]() quote: I'm with Jan! I used to use a NAPA Gold oil filter in addition to the Mobil 1 synthetic. Just recently I decided to switch to the original MOPAR filter. Brian |
Mike Downey![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Atlantic, IA |
![]() ![]() ![]() ![]() ![]() ![]() Same here in Western PA, Mobile 1, 10W30 and the Purolator filter. |
![]() ![]() ![]() ![]() ![]() ![]() Brian - won't make any difference between the two filters you stated. NAPA's top of the line is a very good filter. Note: You won't be using NAPA products much longer |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks pal! |
Butch![]() ![]() ![]() POA Site Supporter Prowler Junkie From:So Dartmouth Mass |
![]() ![]() ![]() ![]() ![]() ![]() Mobil 1 here too ![]() |
Snoman unregistered Admin Use |
![]() ![]() ![]() ![]() ![]() ![]() What are you talking about SNO,,,,,,Carquest doesn't do paint work..... ![]() |
![]() ![]() ![]() ![]() ![]() quote: |
CJ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Lifetime Site Supporter Prowler Junkie Personal ScrapBook From:Rochester Hills, MI USA |
![]() ![]() ![]() ![]() ![]() ![]() We use Mobile One in my cats, too. ![]() ------------------ The Prowler makes you smile. Why? Because it's focused. It has a plot, a reason for being, a passion. It evokes the hot rod. It evokes the American Dream. This car is the human psyche. |
