Author | Topic: Idea For Rear Sub Speaker |
robbieb![]() ![]() POA Site Supporter Prowler Junkie From:Las Vegas, NV, USA |
![]() ![]() ![]() ![]() ![]() ![]() Just put in the 3.5" infinity rear speakers (I already replaced the door and front dash speakers a couple of years ago). Sounds great! As I searched and read through here about folks talking about replacing the speakers...the one common thing was: Nobody could find a replacement for the 6.5" dual voice coil woofer. So I started searching. Couldn't find one either. But then I had an idea. Bazooka makes a 6.5" tube sub woofer http://www.electronicexpress.com/product?brand=309&prod_id=12994 I'm thinking I could just buy that, and then take the actual 6.5" speaker out of the tube and mount it in place of the OEM speaker. Any thoughts? |
![]() ![]() ![]() ![]() ![]() ![]() pm,john c. from kechi ks.he's very knowledgeable about stereo stuff. ------------------ |
jcars05 Prowler Enthusiast From:olive branch,ms,usa |
![]() ![]() ![]() ![]() ![]() ![]() I just replaced my rear sub and found that infinity makes a 6.5 component set that is dual voice coil and 2 ohm like the factory. Ordered mine off ebay 120 bucks. |
tomnafaire![]() POA Site Supporter Prowler Junkie From:Bloomington, IN, USA |
![]() ![]() ![]() ![]() ![]() ![]() Jcars05, What was the specific model# of the speaker you bought? How did it sound compared to the stock subwoofer speaker? Did it fit without any problems? |
![]() ![]() ![]() ![]() ![]() ![]() quote: I just went through all the speakers listed on the Infinity website http://www.infinitysystems.com/car/ |
cplabaunza![]() Prowler Enthusiast From:Bay Area, CA, USA |
![]() ![]() ![]() ![]() ![]() ![]() How about this one: Sold here: http://www.hookedontronics.com/show_product_details.jsp?cid=50840&brandtype=0 |
![]() ![]() ![]() ![]() ![]() ![]() 2 ohm Version: http://www.hookedontronics.com/show_product_details.jsp?cid=50845&brandtype=0 Both are single Voice Coil though. |
bogie55![]() POA Site Supporter Prowler Junkie From:Marrero, LA |
![]() ![]() ![]() ![]() ![]() ![]() I tried all what you all are speaking of the bazookas etc. I wish I know how to post photos on the site ( 4 years and never caught the hang. I went with a custom single 13 inch JBL. and it sounds wonderful. No rattle in the trunk and compliments the sound ( same speaker set up ) well. And when I raise the trunk up it looks wonderful ( custom look ) Just wanted to advise there are other options and I spent/waste all that money and I am very happy with it. |
DublinOH![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:McMurray, Pa, USA |
![]() ![]() ![]() ![]() ![]() ![]() http://www.infinitysystems.com/car/products/category.aspx?cat=COS Here are the infinity 6.5"s. Not sure which one though. |
![]() ![]() ![]() ![]() ![]() ![]() I looked at all the kicker speakers, and the infinity 6.5's as well. None of them are 6.5" woofers with dual voice coil. ![]() |
![]() ![]() ![]() ![]() ![]() ![]() So far other than my bazooka tube raw speaker idea...the only dual voice coil speakers I have found are ceiling speakers for the home. And those are pretty much full range speakers, not subs. |
d'niro![]() Prowler Junkie From:San Antonio TX, USA |
![]() ![]() ![]() ![]() ![]() ![]() Robbieb how about a "Pioneer Premier TS-SW841D Shallow-mount 8" Nic |
![]() ![]() ![]() ![]() ![]() ![]() Here's a 6.5" Dual Voice Coil Replacement: http://www.parts-express.com//pe/showdetl.cfm?&User_ID=9703715&St=7799&St2=-48434820&St3=31722923&DS_ID=3&Product_ID=7559&DID=7 |
![]() ![]() ![]() ![]() ![]() ![]() Someone's project: http://www.monney.com/prowler.htm |
![]() ![]() ![]() ![]() ![]() ![]() quote: Good find! But it looks like it won't fit. ![]() It needs to be a shallow mount. But at least you found one! That's better than I could do. Also those Goldwood brand speakers appear to me to be some real cheap speaker. Not sure how it would sound if it fit. It also doesn't appear to handle much power. Kudos for finding one though |
hollywoodinjax![]() Prowler Enthusiast From:Jacksonville, Fl, USA |
![]() ![]() ![]() ![]() ![]() ![]() i know this thread has simmered off... any updates to the Sub replacments? i am in the market to replace mine.. i would like to keep the original OEM box and just replace the 6.5 woofer. what is the reason for needing dual voice coil? is that only needed if you are keeping the original Amp that is bridging 2 channles into 1 for the sub? i am already in the process of replacing my Amp, thinking a 5 channel so i can have one channle for the Sub. thoughts? |
![]() ![]() ![]() ![]() ![]() ![]() just ran across this Kicker http://www.sonicelectronix.com/item_11395_Kicker+CompVT+08CVT652.html 6 1/2 Shalow mount it is 2-ohm but, it is single not dual. if i am replacing with a Single vioce coil and not bridging, wouldn't i need a 4 ohm? |
838stingray![]() Prowler Junkie From:Schenectady, NY USA |
![]() ![]() ![]() ![]() ![]() ![]() quote: I have two of those in the saddle bag of my Roadglide and they sound great! |
davedem![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Camillus Ny 13031 |
![]() ![]() ![]() ![]() ![]() ![]() Kicker does make a 4 ohm..http://www.sonicelectronix.com/item_11396_Kicker+CompVT+08CVT654.html I plan to remove the stock amp and install an ALPINE PDX-5 channel amp..I already have a Pioneer DEH9600P Head unit and CD changer and Sirius Satellite radio..the front six speakers have been changed..I'm thinking just one of the Kickers to replace the sub...any thoughts? |
binster![]() ![]() POA Site Supporter Prowler Junkie From:cary, north carolina, usa |
![]() ![]() ![]() ![]() ![]() ![]() I've been down this road a couple times. Don't know if these will work with the stock amp due to the dual coil on the stock sub, but here are some options. Bazooka NOS6 sub Kicker sub behind seat and replace stock sub with an Earthquake. Note: The kicker will not fit in the stock enclosure.. The Earthquake is the only model that I found with the correct depth. This message has been edited by binster on 01-16-2010 at 09:39 AM |
alrtg![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Westminster, MD, USA |
![]() ![]() ![]() ![]() ![]() ![]() Binster, So that is how you do it, you simply use NO2 to "Boost" the speaker's performance. I would have never thought of that on my own. Thanks for the idea |
JeraneW![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Hilton Head, South Carolina , USA |
![]() ![]() ![]() ![]() ![]() ![]() I am dumbfounded! What is all this hype about speakers, when the best sound comes from the Prowler tail pipes. LOL |
EdsCat![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Green Cove Springs, Florida, USA |
![]() ![]() ![]() ![]() ![]() ![]() I have this sub-woofer mounted behind the driver seat and just to the right of the center console. It adds a lot of bass to the cockpit. Cost is about $170.00 at most places, but one place has it for $98 plus $24 shipping (to Jacksonville). Heavy duty quality. FEATURES: Peak: 300 watts Impedance: Single 4 ohms |
WINDY CITY PROWLER![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:CHICAGO, ILLINOIS. USA |
![]() ![]() ![]() ![]() ![]() ![]() I have a 12 inch Kicker sub mounted on the passenger side footwell, So no room for a passenger to stretch out their legs. |
BryceW Prowler Enthusiast From:Central Point, OR |
![]() ![]() ![]() ![]() ![]() ![]() I just finished installing a Pioneer TS-SWX251 10 inch shallow mount sub in the trunk running off a dedicated amp I mounted right above the existing factory amp. I built some seat risers, and lifted the passenger seat about 1 1/2 inches (now the seats are the same height!) This provides plenty of space to mount the amp. This Pioneer sub fits perfectly in the trunk right between the hinges. There is nothing you need to modify. It sounds great, and for a 10" sub it can vibrate the hell out of the car! I had to dynamat my license plate since it was vibrating so badly. Hopefully this photo will load. I purchased the sub online at Sonic Electronix.com for $129 (Crutchfield wants $179). I actually kept the existing sub hooked up as well. The combined bass is very good, but I need to work on eliminating the rattles from the stock speaker cover. I highly recommend this sub. |
This topic is 2 pages long: 1 2 All times are CT (US) Top of Page Previous Page | ![]() |
