Author | Topic: Pre-Purchase ?'s |
SNAKE BITE Prowler Enthusiast From:BELVIDERE, IL USA |
posted 09-14-2009 09:01 PM
After a long search, I believe I've found the right car. Please help me out with what I want to look for when going to inspect and pick the car up this Sunday. It's a one owner 2002 bone stock. What do I need to look for while inspecting it? Thanks for any suggestions. Andy This message has been edited by SNAKE BITE on 09-14-2009 at 09:02 PM |
posted 09-14-2009 09:33 PM
Snakebite, I'm sure others will chime in, but one thing I'd ask, if the ball joint recall has been done. Also check under the nose for scratches. |
Midnight Son POA Site Supporter Prowler Junkie From:Wayne, PA USA |
Hi Andy - Speaking from experience (got mine in June), run both windows up and down several times, listen for any noises and make sure they go all the way up. Factory window regulators are so poor that an (excellent) aftermarket unit has been brought to market - cheaper and better than the original. Watch for leaky shocks, dry rot on the tires. C'mon guys, what else that wouldn't be cosmetic or otherwise immediately obvious? ------------------ |
posted 09-14-2009 09:42 PM
Peeling Wheels Check CD Changer Check that the check engine light is not on. |
posted 09-14-2009 10:23 PM
Welcome Andy, When turning the ignition key to the run position, look to verify all the "idiot" lights come on then go off. Look at the rubber bushings on the suspension especially where the shocks may have leaked on them as the fluid could cause accelerated deterioration of the rubber. When running the windows up, pay attention not only to how it sounds but to how smoothly it goes up, if they rattle or hesitate there could be a problem. Look at the inside of the wheels and look for signs of bubbling and or flaking chrome. While you are at it wiggle the center caps on all four wheels. If they have much movement, it is possible that one or more of the clips are in some way damaged. There is a fix for damaged center caps. I would suggest if any of the caps have broken tabs that you immediately have the fix done before they get damaged or lost. Take a CD or two with you. The car has a 6 CD changer in it. Put one or more CD's in the changer and make sure they play. If you get a "No Disc" reading, there may be a problem with the unit or possibly just dust on the lens that reads the disc. I had this issue with mine and a CD cleaner after several attempts succeeded in allowing the player to operate. Look on the deck lid to make sure that it does not have any "Dimples" in it near the latch holes. If it does it is from what I have been told, a result of someone attempting to put the top down before opening the deck lid (trunk). Look for signs of wear on the top in the center toward the front. Most of these issues can be dealt with and if I am mis-informing you of anything, someone will point it out. The people here are always willing to help resolve issues that may arise. You will like it here. Look in Event Discussions for upcoming events that you may be able to attend. |
posted 09-14-2009 10:25 PM
Thanks. I will start a check list to take with me. The owner did tell me the car has some scratches under the nose. I understand those though since I own a viper. Here's my list so far. Peeling Chrome rims?is this outside, inside or both? all years? Windows up/down Cd changer Leaking Shocks?how do you tell if they leak? all years? Ball Joint recall?if not done.... is this free at any dealer? Check Engine Light anything else appreciated |
posted 09-14-2009 10:30 PM
Thanks! A lot of great info here. I must have been typing my last post before I saw this one.
posted 09-14-2009 11:15 PM
Carfax should show any open recalls. I was concerned whether Chrysler's bankruptcy would affect their liablility for recalls, but I had no problem at all getting mine done just a couple of months ago (lower ball joints). |
Paul POA Site Supporter Prowler Junkie From:Cedarburg, WI USA |
posted 09-14-2009 11:26 PM
Snakebite, when you make your final decision on this Prowler, join us north of Milwaukee on Saturday, Oct. 3rd for a drive through the glacial Kettle Moraine area near Fond du Lac. It will be a good opportunity to meet with owners from IL and WI. We welcome you to join us. Check out the details on a post in the Events Discussion section entitled, "Annual Kettle Moraine Park Cruise" for details. |
posted 09-15-2009 01:47 AM
quote:The usual check... oil, etc. More specific things may depend on lower mileage/has it sat long periods. Run it thru the gears with foot on the brake when you FIRST start it up. Make sure when putting it in reverse and in drive that the car actually moves without hitting gas. (In manual mode, I don't think it goes into 4th while sitting still.) Open the trunk and see how it closes. Look at back bottom of trunklid for rub marks. Check for outside tear when top is up at passenger side below rear window. Open hood & see if it stays up. Leave it up while you check everything on the car. Careful it doesn't fall while you have your head or hand under it (weak hood shocks). Are you driving it or hauling it back? (Long drive, possible rain, take a couple bath towels for between each seat and door and a hand towel). Ask for owners manual/any paperwork. Take a camera, sunglasses, and tan lotion. TEST DRIVE IT! Once out of first gear, drop it into manual mode and shift manually to make sure it goes from 2nd to 3rd. Most of all the listed issues are minor. If he cries as you drive away with it, DON'T TURN BACK! This message has been edited by idive on 09-15-2009 at 01:51 AM |
posted 09-15-2009 07:11 AM
Look at the rear suspension. There are 4 rods that connect the wheels to the frame. They have bearings on either end with rubber dust covers. They are easy to spot, two on either side. Check these for wear, these little things cost $700 each! |
