Author | Topic: Please help, Wont Start :( flashing dash lights Wiring diagram urgently needed |
adamdylan Prowler Newbie From:England |
![]() ![]() ![]() ![]() ![]() ![]() I was wondering could some kind person help me. She doesn’t start wiring problem, Previously she would sometimes not start all lights flash and dash lights too flashing. Could just return key and would start. Though it was battery so replaced and cleaned both cables and connections still same problem Had washed. Now wont start at all no cranking whatsoever have tried to separately connect wire to engine from chassis / frame engine as I was told it could be this ground \ earth that is the problem but no joy I am desperate for electrical wiring diagram to try and trace what I think must only be a short somewhere
thanks Adam |
![]() ![]() ![]() ![]() ![]() ![]() Adam, welcome to POA. Up near the Blue Icon that says POST NEW TOPIC there is the word SEARCH, just below it to the right. Click on that and type in wiring or hard start and you will gets tons of information immediately. That is a lot quicker than waiting for replies, especially since you are on a different time zone. FEEL the cables going to the battery. UNDER the cable you might find a worn spot. Either that or you have a bad ground. |
TFischer![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Texas, USA |
![]() ![]() ![]() ![]() ![]() ![]() Same thing happened to mine over the weekend and the negative cable was loose on the battery. |
![]() ![]() ![]() ![]() ![]() ![]() adam,if your cables are tight good,its not the ground.could be many things causing the no start. ------------------ This message has been edited by catfish on 12-11-2010 at 11:55 AM |
bjprowler![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Clarksville,Ohio,USA |
![]() ![]() ![]() ![]() ![]() ![]() Here are a couple of links that you might find helpful...The first is a 193 page "on line" parts catalog...I suggest you save it in your computer...It's a great reference. I'm not sure if there is a wiring diagram in it, but take a look. http://www.oskin.ru/pub/chrysler-dodge/manuals/Chrysler_Service_Parts_Catalog/ CD3/97-01/99PR.pdf The next link will take you to the classified ads...I really reccommend that you buy the complete set of 4 from Gary.. They are a great source of almost anything you'd need to know about the Prowler..It's a "must have" as far as I'm concerned....Good luck This message has been edited by bjprowler on 12-12-2010 at 09:14 AM |
![]() ![]() ![]() ![]() ![]() ![]() that is a parts manual,shows wire looms but no diagram,the prowler has a coupe known wiring problems,do a search-wire loom-it may help.as stated could be one of many things causing it.i suggest taking it to a reputable repair shop.they may be able to find the problem right away,you need somebody famaliar with mopars. ------------------ |
Hairarchitect![]() Prowler Junkie From:Aurora Colorado usa |
![]() ![]() ![]() ![]() ![]() ![]() hmm same thing happened to me last year and it turned out to be the PCM .... |
lionberger![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Grosse Ile, MI, USA |
![]() ![]() ![]() ![]() ![]() ![]() Same with me. "Service Engine" light would flash, wouldn't turn over, turned out to be the PCM. Dealer can tell you for sure. Look at about $1500 if the PCM is bad. |
spoons![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie Personal ScrapBook From:West Palm Beach, FL |
![]() ![]() ![]() ![]() ![]() ![]() How can I tell if the PCM is bad? |
![]() ![]() ![]() ![]() ![]() ![]() quote: Go to a Chrysler dealer and they will run a diagnostic check that will tell you for sure. My '97 would run rough, die and wouldn't start or even turn over. If I let it set for a few hours it would start again and seem normal for a time. Finally it died for good when I left work after going about 50 feet. Work being 15 miles from the dealer I had my wife pull me with her Jeep (in a hard rain storm with no wipers) to the dealer. Luck was with us and we made it there OK. Don't let this happen to you it wasn't any fun. A PCM check at the dealer is easy and will at least put your mind to ease. Good luck. This message has been edited by lionberger on 09-17-2011 at 08:52 AM |
![]() ![]() ![]() ![]() ![]() ![]() If you live in England are there any Chrysler dealers there? Some people own Prowlers in foreign countries where they can't get help from Chrysler dealers but it sounds to me like anyone who knows cars could help you troubleshoot this problem especially dealing with bad connections and such. We tend to jump to conclusions and pick the most expensive parts to replace like the PCM which I have done myself and forget to start with the basics when troubleshooting. If you don't know cars at all you need someone to troubleshoot for you and diagnose the problem and if they find the problem give you an estimate on the repair costs. Taking it somewhere and say "Fix it" can be very expensive! |
![]() ![]() ![]() ![]() ![]() ![]() quote: pedro,,,, this thread was started 10 months ago,,,posted 12-10-2010, so your talking to an **owner who most likely has had their problem fixed long ago. Spoons was just asking for updated, new info on how to tell if the PCM is bad, or going out.
George Johnson![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie From:Katy, TX USA |
![]() ![]() ![]() ![]() ![]() ![]() When my PCM went out, I was showing code P0601. |
![]() ![]() ![]() ![]() ![]() ![]() Thanks A/C, I didn't check the date. |
WildCat![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() POA Site Supporter Prowler Junkie Personal ScrapBook From:North Louisville, Indiana, USA |
![]() ![]() ![]() ![]() ![]() ![]() quote: anyone with a 601 code ..... internal engine control modual fault ..... check with auto computer exchange about replacement PCM, will save you BIG MONEY |
phil2237![]() ![]() POA Site Supporter Prowler Junkie From:PLACENTIA CALIFORNIA |
![]() ![]() ![]() ![]() ![]() ![]() Just for a test, Hold the key in the START position, Move the gear shift from park to low just to make sure it is NOT the neutral safty switch, If it still doesn't start, check your ignition swich.
This message has been edited by phil2237 on 09-18-2011 at 03:15 AM |
