  where can i order new door hand closers
Author Topic:   where can i order new door hand closers
Danielle
posted 11-09-2013 01:02 PM     Click Here to See the Profile for Danielle     send a private message to Danielle   Edit/Delete Message   Reply w/Quote   Search for more posts by Danielle
my door hand closers are broke(the part of the door where you insert your hand to pull the door closed). where can I order new ones? is there an upgraded version of these that aren't plastic?
catfish
posted 11-09-2013 01:11 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
if still available,about 100.00 each.you can still fix them and reuse them, the tabs ar broken.use 100 percent siicone in a tube to reattach them.a few dabs on the back,you will see where it touches,put the dabs there and tape in place for 24 hrs.you can also do a search for door handle bezel thats what they are called.will still be removeable later if needed---tt06dx9aa.you cannot pry them off,they slide straight backwards.doesnt take much to hold in place.to remove put a putty knife under frt edge and tap towards rr of car.
This message has been edited by catfish on 11-09-2013 at 01:23 PM
stevedymo
posted 11-09-2013 01:37 PM     Click Here to See the Profile for stevedymo     send a private message to stevedymo   Edit/Delete Message   Reply w/Quote   Search for more posts by stevedymo
Jan I think she is talking about the Pull Pocket (Door Pull cup).
Danielle go to wholesalemopar.com. There is a left and right listed for 14.82 each. If you need the screw it is 2.18 each.
Old Part Number SV10LAZAA
New Part Number HE36LAZ
Part Name DOOR PULL
MSRP $20.45
Core $0.00
Online Price $14.82
This message has been edited by stevedymo on 11-09-2013 at 01:51 PM
catfish
posted 11-09-2013 01:42 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
youre correct i read it wrong,sv10lazaa.both sides are the same.just snug up the screw,to tight and it wll crack again.
StingRay
posted 11-09-2013 05:53 PM     Click Here to See the Profile for StingRay     send a private message to StingRay   Edit/Delete Message   Reply w/Quote   Search for more posts by StingRay
Jan, in all sincerity ... this is by far your best post ever that I have read. Awesome job!! Your knowledge and expertise here is invaluable.
catfish
posted 11-09-2013 07:44 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
thanks,if discontinued let us know,the older these cars get the less parts available.legally manufacturers have to make parts only 7 yrs. and thats parts that are critical to the operation of the car.interior trim parts are usually the first to go.
ed monahan
posted 11-09-2013 10:12 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
They are the same as a Cirrus or some other Chrysler product.
Stand by for the correct car and you can one at a junk yard really cheap.
Danielle
posted 11-10-2013 06:08 PM     Click Here to See the Profile for Danielle     send a private message to Danielle   Edit/Delete Message   Reply w/Quote   Search for more posts by Danielle
Thanks again.
Gort
posted 11-10-2013 06:19 PM     Click Here to See the Profile for Gort     send a private message to Gort   Edit/Delete Message   Reply w/Quote   Search for more posts by Gort
I've owned several boats. The Marine supply stores have dozens of sizes of these. I don't know if you could find a match or not but all of them are Stainless. Search online you might get lucky
HappyKat
posted 12-01-2013 10:33 AM     Click Here to See the Profile for HappyKat     send a private message to HappyKat   Edit/Delete Message   Reply w/Quote   Search for more posts by HappyKat
I saw some on Amazon or E-bay (I forgot which one).
