  Tire valve
Author Topic:   Tire valve
Itpurrs
posted 07-13-2014 09:16 AM     Click Here to See the Profile for Itpurrs     send a private message to Itpurrs   Edit/Delete Message   Reply w/Quote   Search for more posts by Itpurrs
My tire sensor light has been coming on and the tire pressure is good . But I noticed one of my sensor/valves is cracked, can that give me problems ? And taking off my cap 2 of the clips broke , I remember seeing something on using magnets to hold the . Can someone give me a refresher.
jimsutton
posted 07-13-2014 09:24 AM     Click Here to See the Profile for jimsutton     send a private message to jimsutton   Edit/Delete Message   Reply w/Quote   Search for more posts by jimsutton
Old as these Prowlers are now most likely that the battery in the sensors are bad ..
robin
posted 07-13-2014 07:23 PM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
One method is this way...
Send them directly to Dick Linneman. He thinks he needs me in the equation, but he doesn't need me.
Dick Linneman
Sterling Industries
5642 Victory Dr
Cincinnati, OH 45233
Shipping is $ 10, total, for one or four caps.
Repair is $ 30 for one plus $10 shipping
Repair is $100 for four plus $ 10 shipping.
Mark the back of them with a magic marker and he will make sure you get the same ones back.
He usually repairs them the same day he gets them (or the next day, at the latest). He holds them a day to make sure the epoxy (?) sets and the ring does not get knocked out of place during shipping. You should get them back in about a week from the day you shipped them off. The weekend could delay that a day or so. He does them quickly.
You can remove the tabs and the O ring before you send them to Dick. He breaks them off and throws them away. If you break them off you don't have to worry about them scratching the other caps plus it cuts down on space and weight.
The return shipping is higher because the caps weigh a bit more with the repair.
I now have 9 spares so if you lost one, we can fix you up. If you have extras, I will buy them at $ 15 each.
This message has been edited by ed monahan on 06-30-2014 at 04:27 PM
beachcat
BANNED
posted 07-13-2014 07:36 PM     Click Here to See the Profile for beachcat     send a private message to beachcat   Edit/Delete Message   Reply w/Quote   Search for more posts by beachcat
Magnet mod! Tested, proven, used by many.
http://www.prowleronline.com/ubb/Forum21/HTML/000041.html
Itpurrs
posted 07-13-2014 07:47 PM     Click Here to See the Profile for Itpurrs     send a private message to Itpurrs   Edit/Delete Message   Reply w/Quote   Search for more posts by Itpurrs
Thanks guys. What about the cracked valve stem is that going to give me a problem?
padroo
posted 07-13-2014 11:06 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
I would just replace it and not worry about it. What year is your Prowler?
ed monahan
posted 07-14-2014 12:47 AM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Your sensor is not visible until you take the tire off the rim. When you say your valve is cracked do you mean the valve stem CAP ? If the valve stem is cracked it is probably leaking air and I would think it would go flat within hours if not minutes. That is unless it is just a surface crack and that would not interfere with anything important.
The cap screws onto the top of the valve stem. Inside of that is the actual valve, controlling the flow of air and the valve stem is about 1 1/2 inches long. The sensor is on the bottom end of that valve stem, inside the rim and tire.
