  Prowler "Bottoms out" (((help)))!
Author Topic:   Prowler "Bottoms out" (((help)))!
1st Prowler
posted 12-07-2016 01:42 PM     Click Here to See the Profile for 1st Prowler     send a private message to 1st Prowler   Edit/Delete Message   Reply w/Quote   Search for more posts by 1st Prowler
OK, after loosing (2) mud flaps on the passengers side (completely tearing off the bolts along with the mud flap) I need to know exactly what I need to replace, to keep the Prowler from bottoming out, at large chuck holes & where the road meets or changes at a bridge on the highway and tearing off the mud flaps???? car has 26,000 miles on it & the original suspension still intact.......any suggestions that will help me get to the "bottom" of this is appreciated! Thanks,1st Prowler
This message has been edited by 1st Prowler on 12-07-2016 at 01:57 PM
BeWare
posted 12-07-2016 02:43 PM     Click Here to See the Profile for BeWare     send a private message to BeWare   Edit/Delete Message   Reply w/Quote   Search for more posts by BeWare
There are two things that you can do. Adjust the fenders and/or trim the mud flaps. My front mud flaps have been trimmed in excess of 15 years and no problems.
http://www.prowleronline.com/ubb/Forum2/HTML/000972.html
http://www.prowleronline.com/ubb/Forum2/HTML/001240.html
http://www.prowleronline.com/ubb/Forum9/HTML/001455.html
http://www.prowleronline.com/ubb/Forum2/HTML/000445.html
http://www.prowleronline.com/ubb/Forum2/HTML/000912.html
http://www.prowleronline.com/ubb/Forum2/HTML/001470.html
This message has been edited by BeWare on 12-07-2016 at 02:43 PM
1st Prowler
posted 12-07-2016 02:54 PM     Click Here to See the Profile for 1st Prowler     send a private message to 1st Prowler   Edit/Delete Message   Reply w/Quote   Search for more posts by 1st Prowler
I was unaware that you could adjust the fenders & I do use the "short" version of mud flaps.........how the heck, does one "adjust" the fenders anyway??? Uh.......I will read up on all those remedies you posted!.......Thanks!
This message has been edited by 1st Prowler on 12-07-2016 at 02:58 PM
jimsutton
posted 12-07-2016 05:25 PM     Click Here to See the Profile for jimsutton     send a private message to jimsutton   Edit/Delete Message   Reply w/Quote   Search for more posts by jimsutton
I ripped mine off two times also . I cut off 2" off the oem flaps then used 3 - 1/4" pan head stainless screws and lock nuts drilled and bolted them to the fender they look good and no one knows the difference .. been on for 5 Years now ..
1st Prowler
posted 12-07-2016 07:20 PM     Click Here to See the Profile for 1st Prowler     send a private message to 1st Prowler   Edit/Delete Message   Reply w/Quote   Search for more posts by 1st Prowler
(((Thanks))) JimSutton & Beware ......I thought I was the only one with this problem, so I will soon be making proper adjustments .....Thanks again!
RPL
posted 12-07-2016 09:32 PM     Click Here to See the Profile for RPL     send a private message to RPL   Edit/Delete Message   Reply w/Quote   Search for more posts by RPL
Larry Lord has sold the splash guard brackets to repair the fenders and Tom Mills, Jefferson Auto sells a replacement front splash guard that is shorter than stock.
Richard Gales
posted 12-08-2016 01:05 AM     Click Here to See the Profile for Richard Gales     send a private message to Richard Gales   Edit/Delete Message   Reply w/Quote   Search for more posts by Richard Gales
I actually did the same thing that Jim Sutton did. Drilled 3 holes through the fender. I lost several mud flaps. Never lost another.
Richnew41
posted 12-09-2016 09:29 AM     Click Here to See the Profile for Richnew41     send a private message to Richnew41   Edit/Delete Message   Reply w/Quote   Search for more posts by Richnew41
I recommend Tom Mills, Jefferson Auto mud flaps... They are fantastic.. You can't tell them from the OEM originals yet they are short enough to never give you an issue...
Pure Genius in my book...
BeWare
posted 12-09-2016 10:30 AM     Click Here to See the Profile for BeWare     send a private message to BeWare   Edit/Delete Message   Reply w/Quote   Search for more posts by BeWare
I am not saying its a bad idea to drill holes in the fender to mount the flaps, but a word of caution. If you back up through a pot hole or over a speed bump etc. the flap can get pinched against the tire. The weakest link will then break. If the fender is drilled and flap is bolted to the fender it could damage the fender. It has even happened to others with the stock mud flap brackets. I believe that the chances of fender damage would increase if drilled and bolted to the fender. JMO
See fender damage posts below
http://www.prowleronline.com/ubb/Forum1/HTML/000317.html
http://www.prowleronline.com/ubb/Forum1/HTML/001324.html
http://www.prowleronline.com/ubb/Forum1/HTML/001417.html
http://www.prowleronline.com/ubb/Forum1/HTML/004042.html
http://www.prowleronline.com/ubb/Forum2/HTML/001290.html
This message has been edited by BeWare on 12-09-2016 at 10:32 AM
stevedymo
posted 12-09-2016 11:30 AM     Click Here to See the Profile for stevedymo     send a private message to stevedymo   Edit/Delete Message   Reply w/Quote   Search for more posts by stevedymo
jimsutton
posted 12-09-2016 05:25 PM     Click Here to See the Profile for jimsutton     send a private message to jimsutton   Edit/Delete Message   Reply w/Quote   Search for more posts by jimsutton
I have never had a problem with my 5 yr. fix . but then again I have the molds for both front fenders and can replace them if I were a ever need to ...
MellowYellow
posted 12-26-2016 04:13 PM     Click Here to See the Profile for MellowYellow     send a private message to MellowYellow   Edit/Delete Message   Reply w/Quote   Search for more posts by MellowYellow
Hey, I kind of like that saw-tooth pattern on Ol' Yeller there! Yes, that's my Cat, and it wasn't a mud flap issue. She lost a little bit of her dignity by sitting too close to a fence, and then picking a fight with it! She thought she was tough, and would you believe when you turn the steering wheel, that damn fender reached out and the fence ripped her a new one.....funny thing is if 100 people see this Cat, 101 tell me to "do the other side" to match....SMH
