  relay, fuse, or bcm
Author Topic:   relay, fuse, or bcm
DGCARMA
posted 08-24-2024 11:02 AM     Click Here to See the Profile for DGCARMA     send a private message to DGCARMA   Edit/Delete Message   Reply w/Quote   Search for more posts by DGCARMA
I have an issue when I call for left or right blinker, it doesnt work but hazards work. Rear defrost isn't working and interior fan doesn't blow when turned on. I think I have checked all the fuses I know about and don't see a blown fuse. Anyone have any suggestions?
stevedymo
posted 08-24-2024 12:00 PM     Click Here to See the Profile for stevedymo     send a private message to stevedymo   Edit/Delete Message   Reply w/Quote   Search for more posts by stevedymo
From the service manual,
Left dash area Fuse 6 is for blower motor (fan).
Power Distrib box behind left side panel check Fuse 12 20A for rear defogger. Also ck rear defogger Relay.
DGCARMA
posted 08-24-2024 01:09 PM     Click Here to See the Profile for DGCARMA     send a private message to DGCARMA   Edit/Delete Message   Reply w/Quote   Search for more posts by DGCARMA
Switched both and nothing. Going to hook up a voltmeter and see if it's calling for the fan to turn on. I know forcing the AC relay makes the AC compressor to come on
DGCARMA
posted 08-26-2024 11:32 AM     Click Here to See the Profile for DGCARMA     send a private message to DGCARMA   Edit/Delete Message   Reply w/Quote   Search for more posts by DGCARMA
Any suggestions on bcm diagnosis/repair? I see a place called G7 computers with flat rate pricing. Any opinions?
Tomcal
posted 08-26-2024 02:02 PM     Click Here to See the Profile for Tomcal     send a private message to Tomcal   Edit/Delete Message   Reply w/Quote   Search for more posts by Tomcal
Many of the problems suggest a faulty BCM, except Heater/AC fan.
Fan should work without any BCM commands, unless Resistor Block is fried. Place fan in Max Speed which by-passes Resistor Block.
United Radio has repaired some members BCM's.
http://www.unitedradio.com/industries-we-serve/automotive/
This message has been edited by Tomcal on 08-26-2024 at 02:05 PM
Tony Goertz
Administrating Kat
posted 08-26-2024 02:05 PM     Click Here to See the Profile for Tony Goertz     send a private message to Tony Goertz   Edit/Delete Message   Reply w/Quote   Search for more posts by Tony Goertz
I had a quick look at wiring manual. Fan should work even without a BCM. I believe BCM does control signal lights and Rear defrost.
Dig into Fan issue further first.
STAY AWAY FROM ANY COMPUTER REPAIR SHOP.
Prowler is unique again.... BCM can't even be swapped between model years.
DGCARMA
posted 08-26-2024 02:23 PM     Click Here to See the Profile for DGCARMA     send a private message to DGCARMA   Edit/Delete Message   Reply w/Quote   Search for more posts by DGCARMA
When I have some time I will take a look at the fan again.turning it on max will be easy enough though. The ac light does go on and off with the press of the button but I don't hear the compressor kick on. Still need to find my multimeter to test to see if it's calling for the fan.
padroo
posted 09-01-2024 11:21 AM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
If I remember correctly, anytime the A/C is turned on the transmission cooling fan should run. Easy check, no multimeter needed.
Tony Goertz
Administrating Kat
posted 09-01-2024 05:28 PM     Click Here to See the Profile for Tony Goertz     send a private message to Tony Goertz   Edit/Delete Message   Reply w/Quote   Search for more posts by Tony Goertz
If you are low on Freon - compressor will not turn on but button light will show ON .
