  Steering Rack Replacement
Author Topic:   Steering Rack Replacement
TucsonJer
posted 09-05-2024 02:28 PM     Click Here to See the Profile for TucsonJer     send a private message to TucsonJer   Edit/Delete Message   Reply w/Quote   Search for more posts by TucsonJer
I took the Prowler in for and oil change this morning and ask them to check the front end steering assembly because it seemed I was having trouble with it wandering in the lane and I was always correcting when going down the road. The service advisor just called and said it looks like I need a new steering rack and there was excessive play in the inner and outer tie rods. I’m hoping someone might have information on how to find one. Dealer said they wasn’t able to find one from the factory or outside vendor. Appreciate any input I can get. Jer
cdeluca99
posted 09-05-2024 03:28 PM     Click Here to See the Profile for cdeluca99     send a private message to cdeluca99   Edit/Delete Message   Reply w/Quote   Search for more posts by cdeluca99
Can it cross with something? Not the outer but the rack itself I believe is interchangeable with something? I don’t remember exactly, I’ll look again because I believe I saw something recently. Just curious how bad does it wonder? Check tire pressure and condition. How was the conclusion drawn to it needing a rack etc. how many miles, year? Just watching your back boss, want to make sure you ain’t being taken for a ride. How does your power steering fluid look?
This message has been edited by cdeluca99 on 09-05-2024 at 03:30 PM
johnstuttle
posted 09-05-2024 03:47 PM     Click Here to See the Profile for johnstuttle     send a private message to johnstuttle   Edit/Delete Message   Reply w/Quote   Search for more posts by johnstuttle
Not knowing the details, which Chris eluded to, but I think you are being taken. If not good luck finding outer tie rod ends they are extinct.
alrtg
posted 09-05-2024 04:43 PM     Click Here to See the Profile for alrtg     send a private message to alrtg   Edit/Delete Message   Reply w/Quote   Search for more posts by alrtg
Jer,
While there is always a chance that the Dealer/ Service Writer / Parts Replacer think they are correct in their diagnosis, It is entirely possible that the Dealer/ Service Writer / Parts Replacer were trying to "Up Sell" work that may not really need performed in order to make more money on the job as they often seem to do.
I suspect that they recommended replacing the tie rod ends, or entire rack and pinion assembly BEFORE they actually checked on the parts availability.
I would also imagine they will likely start to "Back Pedal" their story at some point.
My memory seems to recall prior discussions about tie rod ends from other vehicles that MIGHT work on the Prowler's but don't clearly recall the outcome of those discussions.
Check Out these threads:
http://www.prowleronline.com/ubb/Forum2/HTML/003945.html
ivegotsugar posted 02-10-2010 10:38 PM
"I had my driver side inner tie rod replaced back in Aug 09 ...
It was rough trying to find just the inner tie rod since it shows that you have to replace the whole steering rack .
However Don Ward ( 832) 717 - 4977),was able to find a part to fit and so far so good .
Here is the info ... Mopar Steering Tie Rod part # MR519046
This part came from an 01 - 05 2 door Stratus
Cost for part $72.20
Good Luck .... ~ Sugar ~
{Oops I've corrected the Phone #} Thanks Mickey !
Also the inner tie rod will be a different color than the original rod ...Its lighter in color "
http://www.prowleronline.com/ubb/Forum21/HTML/000019.html
http://www.prowleronline.com/ubb/Forum2/HTML/005592.html
Dano posted 10-27-2017 02:28 PM
"Helpful Parts Guy:
I just got off the phone with Chris @ Dallas Dodge (214-319-1228) who was extremely helpful with me to find parts that I needed. I asked if he's mind if I posted his contact info here for others and he said 'please do'. He works with Dallas Dodge parts, specifically in online sales. He has the ability to source parts from private sellers as well as Dodge directly. He said that he constantly helps others procure hard-to-find parts and can take your requests and call you when he finds them. Although he could not sell me the part that I needed, he pointed out the the gas filler neck that I need could be sourced through the Prowler Store - which was correct, they had them in stock and I ordered one today. Very helpful.
Inner Tie Rod ends:
He also pointed out a swappable part number for the inner tie rod end for a Prowler. He said that the Part # MR519046 from a Dodge Stratus would fit the Prowler with equivalent functionality. A little larger, but functional since the old part has been permanently discontinued. I wanted to share that here in case if anyone needs these."
GaryE posted 10-31-2017 11:59 AM
"I do not believe it is a problem obtaining the outer tie rods as they are used on other Chrysler cars. "
http://www.prowleronline.com/ubb/Forum2/HTML/005068.html
ed monahan posted 08-24-2014 02:26 AM
".... before you pay big bucks for a rack and pinion, make sure it is not the ball joint.
There were numerous cases of "mistaken identity" back in the day.
Make sure your ball joint recall was completed and even that is no guarantee that they are still okay."
From an old post in 2002:
"There is a good chance the ball joints are causing your problem.
If the dealer checks the joints the way the book says, they will check out good.
The problem with the joints is that they get too tight. This will require the steering rack to have to build up more pressure than it should.
This is why it is making the noise. If the problem is the joints, It is very possible you may break the ball it stud off while driving!!
MAJOR PROBLEM!!!
Another symptom that goes along with the tight joints that you may be having. Wandering, tight steering, hard to keep in a straight line.
I know of 5 prowlers that had this problem.
At least three of the owners were told the steering rack was bad by the dealer.
I know of one the new rack was installed and didn't help at all.
I know of three prowlers that broke the ball joint stud off. One of which had the new rack installed."
This message has been edited by alrtg on 09-05-2024 at 05:11 PM
Tomcal
posted 09-05-2024 05:16 PM     Click Here to See the Profile for Tomcal     send a private message to Tomcal   Edit/Delete Message   Reply w/Quote   Search for more posts by Tomcal
Excessive play of inner and outer tie rods and a bad steering rack are two different things. One or two tie rod ends maybe, tie rods and rack both, highly unlikely.
Go to an independent shop for second opinion. Preferable one with a lot of front end experience like alignment shops/tire shops. If alignment guy is over 50 yrs, he knows what he's doing.
As johnstuttle and Chris said, maybe you're being taken. Got to be careful of those stealerships.
Info alrtg posted on tie rod ends is accurate. If my memory serves me, there is no interchangeability of rack with other cars. Someone posted way back that he found a shop that can rebuilt Prowler racks. Prowler rack is unique in way its manufactured and how seals are assembled.
As a side note: Wife recently brought her car to stealership for oil change. They said she needed new brake pads and rotors on all four. Told her car was unsafe and can't be driven. Car has only 15,000 miles on it!!!! Checked pads went she got home. Had at least another 20-25,000 miles left, rotors like new. Conversation I had with Service Manager can't be printed. #@%&*
This message has been edited by Tomcal on 09-05-2024 at 05:30 PM
TucsonJer
posted 09-05-2024 05:48 PM     Click Here to See the Profile for TucsonJer     send a private message to TucsonJer   Edit/Delete Message   Reply w/Quote   Search for more posts by TucsonJer
I really do appreciate all of your responses. I think I’m going to get another couple of opinions. It’s beginning to smell a little fishy. My car has 56K miles on it and I’ve had the lower ball joints replaced already. What’s really got me fired up is I found out today that their hourly rate is now $175 an hour. Their estimate for replacement of the rack is over a thousand dollars. I’m going to check with someone who specializes in front suspension work. I’m not going to jump into something I might not even need. I’ll keep you all posted. Jer
Tomcal
posted 09-05-2024 06:54 PM     Click Here to See the Profile for Tomcal     send a private message to Tomcal   Edit/Delete Message   Reply w/Quote   Search for more posts by Tomcal
Good idea, Jer.
padroo
posted 09-05-2024 07:10 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
What I have done is take my car in just for a front end inspection and let them tell what is wrong. After they are done tell them what you were told. Good luck Jer.
TucsonJer
posted 09-06-2024 02:07 AM     Click Here to See the Profile for TucsonJer     send a private message to TucsonJer   Edit/Delete Message   Reply w/Quote   Search for more posts by TucsonJer
I have an appointment the 10th with another shop and I agree Padroo, I didn't say anything except I'd like them to check over my front end. I'm anxious to see what they say.
onecatnodog
posted 09-06-2024 03:38 PM     Click Here to See the Profile for onecatnodog     send a private message to onecatnodog   Edit/Delete Message   Reply w/Quote   Search for more posts by onecatnodog
John(onecatnodog) has one, and like all of my parts I probably payed to much for it when I bought it 10 years ago, along with the power steering pump. But like I said, I do have a Factory Power Steering Rack with tie rod ends.. It could use some new boots on the tie rod ends as I put a small punctured in one of the rubber boots when taking it off a rear ended Prowler. I wanted to post a image of it but it's telling me I need to sign up... Interesting... John(onecatnodog)
onecatnodog
posted 09-06-2024 03:40 PM     Click Here to See the Profile for onecatnodog     send a private message to onecatnodog   Edit/Delete Message   Reply w/Quote   Search for more posts by onecatnodog
Tried again to post but says I must register to post.
onecatnodog
posted 09-06-2024 07:50 PM     Click Here to See the Profile for onecatnodog     send a private message to onecatnodog   Edit/Delete Message   Reply w/Quote   Search for more posts by onecatnodog
I give up.. It still won't let me post a image but lets me post words... Pictures are worth a thousand words.. Keeps telling me that.. "Your not logged in. You must register"
John(onecatnodog)
onecatnodog
posted 09-06-2024 07:53 PM     Click Here to See the Profile for onecatnodog     send a private message to onecatnodog   Edit/Delete Message   Reply w/Quote   Search for more posts by onecatnodog
NEXT.....
Tony Goertz
Administrating Kat
posted 09-07-2024 07:07 AM     Click Here to See the Profile for Tony Goertz     send a private message to Tony Goertz   Edit/Delete Message   Reply w/Quote   Search for more posts by Tony Goertz
John - please try posting a picture in the TEST POST forum. It works for me ..
onecatnodog
posted 09-09-2024 11:07 AM     Click Here to See the Profile for onecatnodog     send a private message to onecatnodog   Edit/Delete Message   Reply w/Quote   Search for more posts by onecatnodog
Doesn't work here either Tony. it will let me write something but not let me post a image. It's probably a good thing as my pictures are mostly Junk anyway. John(onecatnodog)
cdeluca99
posted 09-10-2024 05:56 AM     Click Here to See the Profile for cdeluca99     send a private message to cdeluca99   Edit/Delete Message   Reply w/Quote   Search for more posts by cdeluca99
Not too sure about that lol I seen some pretty good pics from you 😉
This message has been edited by cdeluca99 on 09-10-2024 at 10:30 AM
onecatnodog
posted 09-10-2024 09:39 AM     Click Here to See the Profile for onecatnodog     send a private message to onecatnodog   Edit/Delete Message   Reply w/Quote   Search for more posts by onecatnodog
Your not the first person I have done that to.. It seems that we talked right before that when you called me to talk about my Project Car and as always I'm still hush about it. Slid the phone back into my pocket and it Butt Dialed You.. I have done it to others and they usually reach out to me in person and let me know and we laugh. I must say this is a first time to be informed online.. Never had a issue when I had my Star Track Flip Phone. But I like my I phone even if it has it's draw backs.. Sorry to you and others if I have let you into my life threw my back pocket.. But you must admit it, you listen to it to try to get more info on my project. Haha.
I guess even if I wanted to share images of my secret project I couldn't post pictures of it here. Just tried again with the steering rack image and it says I need to be registered, or logged in. But that doesn't make sense as it lets me post. Gabe offered to post the image but it's not that important to get rid of it. If he needs it he can call me, not sure I want to sell it. John(onecatnodog) No Picture Included.
cdeluca99
posted 09-10-2024 10:29 AM     Click Here to See the Profile for cdeluca99     send a private message to cdeluca99   Edit/Delete Message   Reply w/Quote   Search for more posts by cdeluca99
I apologize if it was a bad way to inform you. I figured you’d get a laugh out of seeing the messages. Hope all is well
This message has been edited by cdeluca99 on 09-10-2024 at 10:29 AM
TucsonJer
posted 09-10-2024 01:05 PM     Click Here to See the Profile for TucsonJer     send a private message to TucsonJer   Edit/Delete Message   Reply w/Quote   Search for more posts by TucsonJer
Just brought the Prowler home from the shop where I took it for a second opinion. All I told them was I wanted them to check everything involved with the front suspension. About 45 minutes after pulling it in they came and told me everything was fine except for the vertical stabilizers were leaking grease from the top and should be replaced and the front tires either had flat spots or the tread could be separating. I ask if they noticed anything with the tie Rod ends or the rack and pinion and was told that they didn’t find anything wrong with them. I just ordered the vertical stabilizers from Spoons and I’m taking it into Discount Tire where I bought the tires and warranty and have them see if they need to be replaced. I’m pretty sure I won’t be taking it back to the Chrysler dealership anymore.
cdeluca99
posted 09-10-2024 03:54 PM     Click Here to See the Profile for cdeluca99     send a private message to cdeluca99   Edit/Delete Message   Reply w/Quote   Search for more posts by cdeluca99
Dude! Awesome save!
ed monahan
posted 09-10-2024 03:55 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Great move on your part. Glad it took a turn in your favor.
TucsonJer
posted 09-11-2024 01:19 AM     Click Here to See the Profile for TucsonJer     send a private message to TucsonJer   Edit/Delete Message   Reply w/Quote   Search for more posts by TucsonJer
I want to thank each and everyone of you for everything you all did to help me. Once again the POA family came to the rescue by offering information and your valuable suggestions that saved me a lot of money and keep me from getting screwed over by a dealership that only cares about making money. Jeff Wallis & Gary Knepper, friends like you are great to have! THANK YOU EVERYONE 🙏👏
