Author | Topic: Inner Tie Rod Replacement |
Niles357 Prowler Enthusiast From:Riviera Beach |
posted 02-05-2010 07:52 PM
Has anyone had to replace an inner tie rod before; and if so, was it a pain or fairly easy? |
posted 02-05-2010 09:22 PM
i believe the inner tie rod cannot be purchased seperatly,its part of the steering rack. ------------------ |
posted 02-06-2010 01:21 AM
By inner tie rod, what are you talking about? I may have a match for you. But if it was damaged from dealer failure to perform the recall on the new arm when installing, get the whole rack new at dealer expense. This message has been edited by idive on 02-06-2010 at 01:23 AM |
posted 02-09-2010 09:11 AM
The inner tie rod extends from the bellows at the ends of the rack. The one on the drivers side has play in it. I've been searching for just the inner tie rod but it appears that I'll have to buy the whole rack. |
posted 02-09-2010 10:50 AM
The inner part just screws into the rack. There is no part to create play. It's either loose or the rack is the problem. Anyone with a chrome front end had to remove this part for chroming. Pull the boot away and hold the ball joint end behind the boot with channel locks and then you can unscrew the rod. Check with Gary Empfield for details. gary@prowlerproducts.com |
posted 02-09-2010 06:02 PM
quote: There is a replacement part from another vehicle out there that will work. I'll have to see if I can find my info on what it's from. If you want the one from a Prowler, you will have to buy the whole rack. |
posted 02-09-2010 06:37 PM
niles,whats wrong with yours.all chrysler rack and pinions come with the inner rods,part of the rack.i seem to remember somebody asking the same question awhile back.you can call adealer and see if theres another rack that will fit a prowler,i dontthink there is.you can buy the tie rod end maybe,but not the inner.had a wrecked 300c,that rack also came with the inners on it also. ------------------ This message has been edited by catfish on 02-09-2010 at 06:42 PM |
posted 02-09-2010 08:55 PM
I've been trying to avoid the dealer cost. ($1300+) Tomorrow I'll pull the boot and take a closer look to see if it's the Tie rod or the rack. I did find a re-manufactured rack from Rack&Pinion Warehouse for 179 + Core. |
posted 02-09-2010 09:20 PM
if you have to go with the reman rack.let us know what happens.ive never heard of a prowler reman rack. ------------------ |
David Veu Casovic POA Site Supporter Prowler Junkie From:PIQUA, Ohio |
posted 02-09-2010 09:47 PM
http://www.jorgenauto.com/rack-pinion/plymouth.html http://frugalmechanic.com/auto-parts/chrysler-prowler/steering-rack This message has been edited by David Veu Casovic on 02-09-2010 at 09:50 PM |
posted 02-09-2010 11:19 PM
good to see something else available.if you buy make sure it comes with the inner tie rods.i wonder if these reman racks are from another mopar product.anybody know.i kind of find it hard to believe these racks came from other prowlers.have not heard of anybodys rack wearing out ever.so where are they from. ------------------ |
ivegotsugar POA Site Supporter Prowler Junkie From:Texas |
posted 02-10-2010 10:38 PM
I had my driver side inner tie rod replaced back in Aug 09 ... It was rough trying to find just the inner tie rod since it shows that you have to replace the whole steering rack . However Don Ward ( 832) 717 - 4977),was able to find a part to fit and so far so good . Here is the info ... Mopar Steering Tie Rod part # MR519046 This part came from an 01 - 05 2 door Stratus Cost for part $72.20 Good Luck .... ~ Sugar ~ {Oops I've corrected the Phone #} Thanks Mickey ! Also the inner tie rod will be a different color than the original rod ...Its lighter in color This message has been edited by ivegotsugar on 02-11-2010 at 01:09 AM |
posted 02-10-2010 11:11 PM
I might be wrong, sugar, but I show Don's number you listed was his fax number. I show his shop number to be 832-717-4977. Correct me if I'm wrong. Thanks for the info. I thought I had that, but couldn't find it anywhere. |
posted 02-11-2010 01:21 AM
That is really good info. Thanks for posting it Sugar. This is the type of thing that makes the POA the most valuable site on the web. |
posted 02-11-2010 05:52 PM
I just installed the new tie rod and it's working fine. That was great info. Saved enough money to spend it on some accessory instead of necessities |
posted 02-11-2010 07:06 PM
did you have the alignment redone. ------------------ |
posted 02-11-2010 11:03 PM
I just wanted to add , that after the inner tie rod was replaced ,an alignment was done on my vehicle ...
posted 02-12-2010 11:51 AM
I found some old literature that stated that the steering rack is a modified minivan rack. What the modifications are I am not sure of. |
posted 02-12-2010 01:51 PM
I'm getting an alignment today. Thanks again for all the help you guys are a life saver. |
posted 02-12-2010 08:32 PM
MDProwler I was told the same thing , however after trying to compare the mini van rod sizes, one was too long and the other rod was too short. After a week or so days of trying to locate a rod to fit ,Finally the only rod that came close was the 01 - 05 2 Dr Stratus .Belive me when I say that the parts guy at the dealership took my rod and sized it up to everything he had in stock ,it was long and tedious , but he accomplished the task ...I'm glad we have Don Ward here in Houston . |
posted 02-12-2010 09:07 PM
Ya hear that, Don? I think Tom said it first... Move, and you're dead. |
posted 02-13-2010 06:33 AM
quote: This message has been edited by MDProwler on 02-13-2010 at 06:34 AM |
All times are CT (US) Top of Page Previous Page | Return to Prowler Reproduction Parts Discussion next newest topic | next oldest topic |
