Want to register? |
You can do a search and find many threads about the rear rotors. This message has been edited by LSK on 06-24-2019 at 02:47 PM This message has been edited by robin on 06-24-2019 at 04:56 PM part number 04815750 Rears are a special composite . don't use ceramic pads. So far only OEM work. To much money to drill. http://www.summitracing.com/int/parts/mop-04815750/overview/year/2001/make/chrysler/model/prowler This message has been edited by robin on 06-25-2019 at 10:00 AM Mulholland 01 Afternoon gentlemen... I am looking for front and rear cross drilled (dimpled) and slotted rotors. I have searched endlessley for a good brand and can't seem to find anything? I looked at EBC brakes but they only have the front and do not have an estimate on anything for the rear. I really would like to get matching but I can settle for front cross drilled (dimpled) & slotted and the rear just slotted. Any advice?? Thanks LSK The front rotors are steel and replacements are easily found. The rear rotors are a composite aluminum material and only work with organic brake pads. I'm not sure if anyone is making a replacement rear rotor. Using anything other than the organic pads will heat up the rear rotors too much and ruin them. Mulholland 01 Gotcha.. that’s where I’m running into the problem. Anyone else care to share... robin I have these work and look great .Ceramic pads for no dust... Mulholland 01 Thanks for the info.. Now i'm trying to locate the rears robin http://www.moparpartsoverstock.com/p/__/ROTOR-Brake/6658639/04815750.html
That last a long time if treated right.
