Topic:FRONT BRAKE DIMENSIONS AND LUGS
WILD THINGhey guy's and girls.
does anyone know the lug size for the prowler?
12mm?
also i cant find the spec sheet for the front brakes system that was wildwood products offered by fellow prowler member which i beleive is no longer in business scott?
i just need the size of the caliper and the rotor i thought rotor is 12"
i want to do 18" rims on a 245/40/17 tire with the brake setup and making sure no rubbing going on.
condorMaybe this helps
This message has been edited by condor on 02-05-2008 at 02:15 PM
condor
condor.
This message has been edited by condor on 02-05-2008 at 05:41 PM
WILD THINGthanks guy!
condor
obi-wanI'm still very much in business and I continue to make the brake set up for the front brakes. If you need info in this please call me at 650-967-3609 and I can give you any info you want. Just leave a message and I'll get back to you a.s.a.p. Thanks, Obi-Wan
bobbrideDo you have pictures? I am interested too.
Thanks!
quote:
obi-wanI have great pictures in my catalog. It's free but I do need some info. from you to get the catalog. I need your name, address, phone no's. The year, color and what you've done to your Kat(stock extras as well as after market ones). You can e-mail it to me or call me(no. above). I hope this helps, Obi-Wan
bobbridethanks Obi-wan, I will call you. Look forward to the catalog.
This message has been edited by bobbride on 02-24-2008 at 12:26 AM
