first mopar | Can anyone tell me the best places under the Prowler to put 4 jack stands to keep the tires off the floor? |
Snickers | This is from an old post: http://www.prowleronline.com/ubb/Forum1/HTML/011928.html |
first mopar | Snickers, Thank You but that site only shows where to lift the car. I would like to know where to place 4 jack stands to let the car down on them. |
Michael Pond | Same place.. |
idive | Same locations. And to answer your next question, jack the car up at a nearby location and place your stands at the spots shown. You can actually jack the front up on the pad and still place the stands on the pad if you place the jack right. Be careful not to get on the body panel - it's close. May need to slide the jack in and back from the opening by the front wheel. An alternate method is place a 2x4 about midway on the rail under the door and use that as your jacking pad. |
first mopar | idive: Thank You for that information,that is what I will do. |
