Topic:Lambo doors question
GortDoes the wiring going from the body to the door have to be spliced in order to get a longer loop for the door opening?
Thanks..still considering the Lambo door.
ProwlerCarthis might help you
http://www.verticaldoors.com/_product_pics/universal.pdf
xtreme prowlerVertical Door Inc kit included a couple of wires to extend the power mirror... that is the only wires that need modifying...
ACCLER8This was from the PDF above:
"In order for the vertical hinge to sit flat against the apron you might have to cut, drill or well depending on you particular vehicle. "
For this product to fit, do they have to do any vehicle modification to make the hinges sit flat? Do they have to cut our fenders or our doors to allow the swing arm to fit?
Alec
