Topic: | Light Switch Bezel Replacement..Chromer Wins First Round. .Bezels Win Second..HELP! |
Chromer | The replacement Headlamp Bezel came in Wednesday. The fighters:..(the Bezel brothers and Chromer)agreed to meet on Saturday morning. Chromer clearly won round one! Chromer sprayed the replacement little bezel feller in the eyes, re-enforcing his protruding tangs with HOT GLUE! The Bezel Brothers clearly won round two. Chromer was completely unsuccesful trying removing the light swith shaft to ge a clear swing at the wounded bezel brother. Mrs. Chromer called off the match after watching her hubby fight the bezel's with every weapon he had. HELP.. I'v bent tip cleaners..mangled screw drivers with no success. What tool should be used to relase the light switch shaft? Chromer
WildCat | on all the older cars that I have had the switch out of, there is a pin on the switch itself that releases the shaft and after looking in manual on page 8E-12 it states 1.open hood 2.disconnect battery & isolate the neg. battery cable 3.remove instrument panel top cover 4.disconnect wiring from switch 5.remove switch knob by depressing the release button on the bottom of the switch and pulling out the knob from the switch 6.remove the knob bezel looks like 35 years later they use the same system
good luck 6. ------------------ Larry & Sue Mayes |
Chromer | Hey Wild Cat.. Thanks for your reply. I did look it up in the service manuel on page 8E-12 (it's not like me)and that was no help . Jack usually takes care of these small jobs for me . However, he got a dab of that (REALLY) HOT glue on his paw! Now he won't come back into the garage to help out at all. Still need HELP!! Chromer
neal | wildcat is right, dash pad off unplug light connector.force your hand down and around the light switch the release button is on the bottom.you may loose some skin have Band-Aid ready. |
ALLEY CAT | Chromer - there you have it,,,,straight from Neal our certified Prowler tech. Thanks Neal After reviewing an instant reply of the match between Chromer and the Bezel Bros.,,,,,,,,,,,,,,,,I've decided that Jack should be the one to finish the match against the MeanAs$ Bezel boys!!! He is a fighter and a pisser Good luck JACK, Your buddy AC ------------------
Call 911 - there is a Prowler in my garage....
LARRY SALZMAN - MESA, ARIZONA
Chromer | quote: Originally posted by neal: wildcat is right, dash pad off unplug light connector.
Neal-All, Thanks for your response. I was hoping I wouldn't have to remove the dash pad (yipes..I think they are about $900). The temperature here in Denver is now 60F (NICE!!). Should temperature be a factor to be conidered when pulling the plastice dash pad: Any good tips you can share to minimize my chances of damaging the dash pad when it's pulled.
Geezzz..I'm worried...
ALLEY CAT | Chromer - in the event that Neal doesn't reread this thread, you might want to email him direct or private message to him. Still,,,I'm going with Jack to do the work |
WildCat | here is how I took my dash cover off I could not get my fat short fingers to grab the dash good enough so I made a TOOL out of a stiff blade 1 1/2" puddy knife. By making a bend in the end of it to create a 1/4" hook on it then using a towel to protect the dash I hooked it under the dash by the windshield. Then grabing the dash between the speedo & guage to the right (I don't remember what one it is) wiggle and pull straight out. The clips that hold the cover on are all around the painted section. the area next to the windshield only has tabs to locate to cover. The guy at CAAP that showed me how it came out only grabbed the dash and pulled it straight out in about 5 seconds. I do not think the cold will make any difference. You might go ahead and do the squeak protection while it is out even though it might not squeak now, it might after being disturbed you might try to see if you could go from the bottom and get to the switch to release the knob, but on the covette I had to change the switch on the only way to get to it was remove the dash pad give jack the book and he will tell you HOW TO DO IT....LOL
Chromer | Wild Cat / All, Thanks for your suggestions. The dash pad is safely off and in the basement. Now that frisky bezel is in for..next weekend..? |
ALLEY CAT | Wildcat - thanks for your input. Do the squeak protection while it is out??? Are you talking about what Bill Galagher did with foam tape inside the dash? thanks |
WildCat | quote: Originally posted by ALLEY CAT: Wildcat - thanks for your input. Do the squeak protection while it is out??? Are you talking about what Bill Galagher did with foam tape inside the dash?thanks
YES |
