Topic:REAR VIEW MIRROW
DON WIEBERthe mirrow does not show the directions any more. took back to dealer. he told me to look for a different one. is there any other car mirrow that is a match or do i have to buy a new one?
catfishprowler specific.un hook batt cable and rehook and see if it resets itself.also do a search rr view mirror,i remember about a yr.ago,somebody else had similar problem.
idiveAren't you suppose to do do-nuts if your compass goes out?
DON WIEBERwe did do-nuts till we were dizzy. it still said ne.
SuperDaveI bought a new factory rear view mirror several years ago because I was hoping to find a way to get temp and compass in my 97 but my local mechanic couldn't figure out an easy way to make it work with my early electronics.
If you end up needing a new one feel free to make me an offer on it!
Dave
This message has been edited by SuperDave on 07-22-2009 at 11:00 PM
