Topic:return gas line popping off
billy the mootJust a bit of information which may help someone in the future......
One day this summer I was driving the kat and smelled gasoline badly!! As I was turning the corner the car stalled out. I opened the hood and didn't see anything that looked wrong or out of place. Looked under the car, nothing.
I tried to start the car again and the gas smell was worse than ever. As I looked under the car again I was surprised to see a 4 foot round puddle of gas under the tank. I immediately pushed the car about 10 feet forward to get it out of the puddle, just in case someone tossed a butt out their window and my car would be gone. Well, now to find the problem. What I found was that the gas return hose that leads back into the tank, had simply popped off. This was found under the carpet in the trunk area, and under the gas inspection plate. For some reason the .50 cent plastic clip just came off. Even when it was on it felt loose. So to be sure, I folded a cloth to about 1" thick and placed it on the top of the fitting. When the inspection plate was screwed down it held the cloth in place and that won't be a worry again. If you haven't had this problem, maybe it will occur sometime and you'll remember this as the first place to look...Happy Trails......Billy the Moot
pumpkinGood info.
Current mods: Mopar dual exhaust & front mudflaps; MacMotorsports Air Intake;
Real Rod Air Patrol; Graphics by Balistek Designs; ($8) Chrome grille; Chrome
tire valve-stem covers; Painted rear bumper lettering; Prowler Pro Gears; Synthetic
Oil; Raybestos Ceramic Brake Pads; TGF Door Panel Inserts & Headrest Covers;
SheepskinExpress Sheepskin Seatcovers; Grille Light; Pinstriping by Bo Boring;
Painted Valve Cover; Window Tinting; Windshield Visor Banner; Front Bumper
Removal / Relocation of Front Turn Signal Lights; Real Rod Transmission Cooler
Cover, Sill and Carper Covers, Aero Front Covers and Roadster Rear Pan, rear
bumpers removed; rear mudflaps; painted calipers; Prowler Products by Gary
Drilled Rotors, front and rear; Painted tach; and Jay's Aluminum Billet Center Caps
w/shimmers, Chrome Lugnuts and Chrome Radio Bezel Shimmer, Dash Rings,
Windshield Wiper Arm Removal, Fender Trim and Speaker Replacement.
More 'Pumpkin' photos . . . . . More cars and other stuff
New pictures in Personal Scrapbook (02/23/03)
"I may have to grow older, but I do not have to grow up!"
